Another Pi Intake Question?
2K views 18 replies 8 participants last post by  MikeD05GT
#1 ·
Hello i have a few questions. I have read a couple writeups and some differ. What do i need to have to get the manifold to fit on romeo pi heads on a 98GT. I know i need a coolant tube, but what else? I read that theres some sort of adapter, is that needed? What about Bolts do they change to or can i use my old ones? thanks
#3 ·
no adaptor needed. pi intake on pi heads, u need coolant tube(or 3ft of 5/8th heater hose) pi intake gaskets, and of course having it tapped. you can reuse the bolts from your manifold but not for your heads.
#8 ·
ugh, not like a faucet. Its just a hole from drilling it, and the threaded so you can screw the temp sending unit down in there, and that is done by the tap.
#10 ·
I'm pretty sure everyone gets it now. But to be clear, the blank needs to be drilled so that there is a hole for the temp sensor. After it's drilled to the appropriate size a "tap" is used to create the threads necessary for installation of the sensor. A tap is like a bolt, but super hard and sharp for cutting threads into soft metal.
Again, I'm sure you realized this, but wanted to make it clear if not.
