1 - 2 of 2 Posts
Discussion Starter · #2 ·
I'm trying to figure out how much boost I can run on pump gas. My static compression is 9.3:1. After doing some research my understanding is that dynamic compression has more of an impact on how much boost you can run. Here is where I am getting stuck. If I use this calculator if I input my static compression of 9.3:1 and boost of 6psi I get a "Boosted compression ratio" of 13:1
http://www.wallaceracing.com/boost-c...ratio-calc.php
However if I use this calculator to determine my dynamic compression using the following input I get this outcome:
http://www.wallaceracing.com/dynamic-cr.php
Cylinders: 8
Bore: 4.125
Stroke: 3.4
Rod Length: 5.315
Static compression: 9.3:1
Inlet Valve Closes ABDC: 74
Boost Pressure: 9
Target Altitude: 345
Static compression ratio of 9.3:1.
Effective stroke is 2.43 inches.
Your dynamic compression ratio is 6.86:1 .
Your dynamic cranking pressure is 129.99 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 9 PSI is 11.06 :1.
V/P (Volume to Pressure Index) is 101
My Cam:
35-775-8 - XFI? Stroker Hydraulic Roller Camshafts, Computer controlled (E.F.I.) with O.E. hydraulic roller cams 1985-95
Can somebody tell me what is the more important number here and what kind of boost I can really expect to run on this engine?
1 - 2 of 2 Posts
