1 - 2 of 2 Posts
it all started when she coded cam poistion sinsor chaned it 5 times changed plugs 2 times changed egr valve checked vaccum lines did have a code for the no 8 cyl missfire pull the plug check gap did see a little oil high on the plug but the end in the cyl was dry as a bone chaned out the alt still missing when i stomp on it it seems to be tring to go but its holding back best way to explain its like its pulseing its tring but holding back and at a steady 30 40 it studders bad im going to try changing the plug maybe one weak :eek::( i do not get it
1 - 2 of 2 Posts
