First off I know this sounds like a weird question and I've to do a bunch of research while not coming up with much. Basically I'm going to be pushing around 15+ lbs of boost into a 10.5:1 CR motor and plan on using meth along with an Intercooler. My tuner knows how to tune using meth just for cooling but is still concerned that meth systems are unreliable in his experience (he's been building and tuning Mustang's for almost 30 years so I trust his opinion).
I've been looking for a way to use the output (12v signal) of an AEM Flow Fail Safe to trigger some kind sensor or something else to trigger a type of Fail Safe. I know our cars don't have a fail safe exactly but they do have a limp mode, FMEM mode, traction control etc. I've looked at the MSD 6 Box but the unit and the needed harness for our cars is almost $800 dollars and most places the harness is unavailable or discontinued......
I know I could just shut off the pump (A1000 return style) But that is not really ideal since it is a street car and honestly I'm not sure what would happen if the pump shut off at 5k in gear (5 speed). I've contemplated using an MSD 2 Step to cut spark as well, not sure if it is possible or safe either. I've thought of using a relay to open the signal or power wire to the MAF but not sure if the ECU will react correctly or even quick enough to save an engine. I considered making the coolant temp sensor read high as well but there is no safety procedure programmed into the ecu for that either. I also thought about using a relay to open the TB sensor but once again not sure if that will work either. I know I could just use a warning light as well, but damage can happen in less than a second and I'm not that fast.
Any ideas everyone??
