Status
Not open for further replies.
1 - 20 of 105 Posts
Looking to compare combos and 1/4 times.
Anyone over 1000k to the wheels?
I have a TH400 so I doubt I would hit 1000k unless I switched back to a T-45.
Thanks
I highly doubt you would hit 1000 with that setup even with a 5 speed.
You're probably right. I'd be right around 900-950 with a t-45.
You got your dyno'd yet?
Yea probably around 900rwhp.
My car dynoed 1219rwhp/1154rwtq
  • Like
Reactions: JoshDrex00gt
BYAHHHH!
you times will be slower with a t45 then a th400...
BYAHHHH!
I think he used c16....
whats the weight of your car, what turbo, tires, stall, gears, ect?
Discussion Starter #11
3200 w/ driver, Precision 76HPSH, 3.27, 28 x 10.5, unknown stall speed yet, still working out some bugs.
I will upgrade to a bigger turbo if I don't get 8.99 at 150 like I want. Sticking with 2v.
Discussion Starter #12
BYAHHHH!
transbrake?
Discussion Starter #14
BYAHHHH!
you will need a laundry over 150mph no?
Discussion Starter #16
It doesn't have a chute yet but you are correct, if I go over 150, I'll be booted. But hopefully if I hit 150, I have gone 8.99 as well so my goal will be met. The cage is good to 8.5 and everything else it up to spec.
Cobrastang is 4v... you have 800rwhp 2v. Just out of curiousity, are you using a turbo kit of some sort or is it all custom? Also, what heads and intake? You can PM me if you'd rather not make a list here.
Discussion Starter #19
I understand he is a 4v. Just like to talk toother modular high horsepower turbo car owners.
Custom kit from Vettes and Performance in Kansas City KS.
Block - Iron block / 19cc (9.2cr) coated diamond pistons / Manley Rods / Cobra Crank
Heads/Intake - VT Stage II ported PI heads and Stage II ported bullitt intake.
Cams - MMR Stage II turbo cams
Computer/Harness - Painless body harness / Big stuff 3 with ls1 coils
Cage - 8.50 cert
Turbo - Precision billet 76mm HPSH with a .96 a/r T4 exhaust housing / Tial 50mm BOV / Custom build by V&P Racing
Transmission - TH400 with a JW Ultrabell built by TCI with a transbrake and a full manual reverse pattern valve body / PTI converter
Fuel system for E-85 - Magnafuel protuner 750 pump / magnafuel fuel fitler / -12 AN line to the pump / -10 from pump to Y block / -8 to each rail / -8 from the rails to a external regulator / 6an return / 120lb injectors
Rear end - Moser Spool / 35 spine axles / 3.27 gear / C-clip elim
Holy ****!!! I forgot it was that high. Man if Im ever in NY you have to take me out for a ride in that beast. If you do, Ill consider trading you my GT brakes for your Cobra R brakes :shiftyeyes
1 - 20 of 105 Posts
Status
