1 - 20 of 21 Posts
UCC
My car is lowered on steeda lowering springs and i have bbk upper and lower control arms with kyb shocks all around but i scrape everywhere
Sent from my SPH-D710 using AutoGuide.Com Free App
UCC
Discussion Starter · #2 ·
I tried bolting up my exhaust a bit closer to the body but it didn't do anything also I'm tired of dragging it on bumps and the small sub frame bar under the cars is being grinded away, my question is; is there any exhaust that sits closer to the frame than the stock exhaust i have
BTM AutoSport
i have no problem with my car and I'm dropped on C/O's with longtubes which are lower than a stock mid-pipe. I can tell you right now that your exhaust is not done right. whoever welded it, did not think about tucking it closer to the underbody and that's why you're scraping so much.
:facepalm:
Somebody did not take the time to measure. The downpipes coming off the headers are too long and are pushing the hpipe down further than it should be. Shortening the downpipe will bring the hpipe back up to where it should be, but the rest of the exhaust will no doubt need rehung. No matter how you look at it, your exhaust needs redone. thats the only fix. Do it just right and you can use band clamps (like BBK uses) between the downpipes and cats instead of a solid weld for a bit more wiggle room. The clamps will take up some slack if the cuts are too wide. How much depends on the clamp. BTW, why is there an airtube on the outside of the cat? Im guessing the hpipe was pieced together from spares?
As for the subframe scraping, thats the price you pay for going too low. Only fix there is to swap a taller set of springs.
forget having the exhaust not hung right, it looks like your pinchweld and frame rail are destroyed
:eek:
Dude... your frame rails are ****ed
How the hell did you manage this? Do you have any pics of the whole car?
Yeah... Your whole underside from that pic needs redone. I as well have longtubes and am dropped a little over an inch and i hardly scrape. Though i am cautious.
BTM AutoSport
:facepalm:
+1- If you are on a budget replace that set up with an inexpensive OR X or H. You can add the cats if needed later. On your frame rails, somebody used a floor jack where it wasn't supposed to be.
The Mean Green
+ 1 it was amateur hour at the exhaust shop. It's welded at an angle
UCC
Discussion Starter · #15 ·
The frame rails were like that when i bought the car and the exhaust was as well i found a bassani x pipe on craigslist which is probably what ill pick up this weekend
When you put the x pipe on, before you tighten it down to the manifolds and catback, put a jax under the cross over on the midpipe, and jack it up. Then tighten down the manifold nuts, then catback.
It'll sit up a lot higher. And won't have issues
This is what I did and it dosnt hang at all
nothing a little UPR x pipe cant fix...gain power and its closer to your cars bottom. i have H&R Race Springs with KYB shocks aswell and I dont ever scratch...but I do have 18's with tall tires...
UCC
Discussion Starter · #19 ·
I live in the country side of texas as well where roads are crappy so i assume ill scrape more than y'all but still btw how low do pacesetter headers sit? And what is so bad about them that makes them unpopular
1 - 20 of 21 Posts
