1 - 8 of 8 Posts
I am thinking of ordering the extreme lca and uca with the adj pandard.
Im kind of stuck, I was wanting the double adj lca. Whats the big diff between adj and non adj lca's. Any input will help, thanks.
You had one job!
Just go with an adj Uca and non adj lca. Then you have only 1 point to adjust, which makes it much easier to set it up right.
Yup. On the older stangs that had 2 uppers and 2 lowers, it was easier to access and adjust 2 points that were under the axle rather than above it. Unless you are REALLY serious about getting everything exactly to the upmost perfect, than you dont need adjustable lowers.
yup its eaiser to adjust at one point instead of to right. I got a set of umi non adjustable (greaseable,black)lca's stiiting in my garage for cheap if your interested and a uca mount as well. btw J&E? never heard of them, you mean j&m ?
I have the J&M billet lowers and have no regrets. I also replaced the upper with an adjustable and the 2 combined eliminated all wheel hop. I highly recomend the billet lowers, they are light weight and look great.
you have a pm:) lol 999 posts
1 - 8 of 8 Posts
