1 - 5 of 5 Posts
i need some parts for my 86 SVO and im wondering if anyone has the OEM part numbers or knows where i can get these things...maybe both.
1) headlight switch
2) turn signal switch
3) power steering rack & pinion
4) turbo oil return line
5) transmission mount
6) motor mounts
7) transmission seal (*its the one on the rear of the transmission that the drive shaft goes into*)
if anyone could maybe help me with some part numbers it would be great. hopefully some of you guys could help. thank you.
i can get you any of these parts that you need out of a svo that i have used, or u can probably just go to oreillys and ask them and they can get them.
if you could get them that would be great. im having a hard time finding them anywhere. im in ct so i would pay shipping if in fact you can get them
Turbo oil drain line can be found on Stingerperformance.com
I linked you to a source for the motor mounts in another thread, either that place or go to a junk yard and pull some there. That would be cheapest.
Same thing for all the others except for the transmission seal. You could find all the switches from a junkyard 2.3 car, and the rack and pinion as well.
1) headlight switch
6) motor mounts
Headlight switch, mounts, seals, and rack and pinion available at Advance Auto Parts. (I used to run one of these stores). Oil line is at forced4.com. Good luck!:)
1 - 5 of 5 Posts
