1 - 4 of 4 Posts
I have the Metco 11/16" rails installed and had to go through some changes in order to make them work and I was wondering if anyone else has a different setup installed.
stock fuel rails can handle 600+rwhp, u dont need it. but since its on, and working then its a good setup.
May 08 ROTM
I see he flipped it so the crossover line is in front, but I'm curious as to the rear plug. on the driver side. I'm also curious as to the cluster **** you will be going thru when you need to change an injector and such.
Did you have to hog out the manifold for clearance of the rail to get it seated deep enough?
1 - 4 of 4 Posts
