1 - 12 of 12 Posts
im going on a trip in a few weeks, and my cruise doesnt work.... it used to though, the covers for the buttons are missing on the on/off side but its just the covers the buttons are still there, and since it used to work, i dont think that is the problem.
ive tried putting my foot behind the clutch and pulling up but that didnt work. any suggestions?
!FACEPLATED!
could be the switches, could be a fuse, or it could even be the cruise control its self that is inside the drivers side fender
ill check fuses tomorrow. didnt think about that. were is the fuse located.. engine or inside cabin?
!FACEPLATED!
check them all. im not sure which one is for the cruise control. but if you do happen to need the module or switches, i have them for sale :)
!FACEPLATED!
80 shipped. less than 30k miles on the unit
Your cruise control cable behind T/B might be loose
Discussion Starter #9
you wouldnt happen to have a picture would yah?
it because this could make since, because its a new motor
I don't have a pic sorry but if you pull you accelerator butterfly of your TB, the cable im talking about is next to your left pinky finger?
Too Soon, Junior!
Fuses 17, 33, and 35 pertain to cruise control functions. I kinda doubt it's a fuse issue though, as a few other circuits would turn off with the fuse blowing. Have you installed any clutch adjustment components or LEDs in the car?
Probe the clock-spring harness with a multimeter and test the CC switch outputs. If it's a switch issue, I can send you a schematic on building your own control circuit for the cruise control system.
1 - 12 of 12 Posts
