I'm curious to know if anyone on here is running a D1? I would like to know your set up and possibly your numbers.
That will be a very fun car. Will you be running your meth kit as well? If not, do you want to sell it?I've got a D1SC that I'm almost done working the kinks out of.
Basic mods:
-3.4" pulley on stock crank pulley
-Gigantic 4" air-to-air intercooler
-Anderson powerpipe
-SCT BA5000
-60 pound SD injectors
Motor mods:
-Ported PI heads
-Stage II MHS NPI blower cams
-Bullitt intake
-Exhaust
-Built bottom end
I'm at least 90% done with it. Have had some fuel supply problems, but I actually think I've finally resolved all those. Only thing left to do is retune everything (I do my own tuning).
On the last few pulls I made on it, everything was gravy up to about 5500 rpm, where it was running out of fuel. Below 4000 rpm, it's a little laggy, which I guess is typical for centri blowers (I've had a PD blower on my car for the previous near-decade). But at 4000 rpm, holy smokes does everything start coming together. I guess the heads, cams, intake, and blower all start working together at about that point, because she flat GETS DOWN from there.
With this setup, I'm seeing nearly 15 psi at 5500 rpm when I have to back out of it. Even at 11.2 AFRs, 10 degrees of timing, and only turning to 5500 rpm, this setup puts my old Eaton setup to shame (which made an honest 420 rwhp and ran 11.5s @ ~120 mph). I can only imagine what it's gonna feel like once I throw a few more degrees timing at it, lean it out a tad, and actually turn it to 6500 rpm. I don't think it's going to have any issues running well into the 10s at 130+ mph. The mass air flow rate that I'm datalogging is suggesting somewhere between 550-600 rwhp.
The car is definitely a hoot to drive, but I'm still not convinced that the laser-flat torque curve of the Eaton setup wasn't more fun, even if it did make less power. Maybe I'll change my mind once I get everything completely dialed in and crank the tune up a bit.
How much boost are you running?Here is my set up.
2000 Mustang GT
tr3650 swap.
Procharger D1sc
4' 6 rib pulley
3 core intercooler
Deatschwerks dw300 fuel pump
60lb inj
vmp 5000 MAF
Tial BOV
Accufab plenum/75 tb
Bassani catted x pipe
Magnaflow Magnapack cb
Ford 3.73 gears
295/40/18 rear nittos nt555g2
Exedy Clutch
377whp
Are you sure you have a D1? Your numbers point more towards a P1.My set up made 377/377 @10psi.
I'm thinking of adding an Anderson power pipe, a bap, and a different pulley. I wonder if I would be able to break into the 400's. What do you guys think?
Just seems low for 10psi. I’m running a Vortech V3 about 6-7psi with a 3” intercooler and a powerpipe and mine made 367/387 on conservative tune. Only other mods I have are a midpipe and catback.My set up made 377/377 @10psi.
As an FYI....my setup is on the stock Procharger Cold Air Intake...I'm thinking you do not have a D1 or something.My set up made 377/377 @10psi.
I have the same blower. Is 14psi the max it can make?Not sure the difference between blowers but I have a V3 Si trim - 14psi with blower cams did 518rwhp.
No this Si trim can make around 20-22psi maxed. The 14psi was with a 3.15 pulley 6rib which limits my capabilities until I switch to 8rip. Or I could go with a overdrive pulley. It made 16psi last year with the stock cams.I have the same blower. Is 14psi the max it can make?
He has a D1. He's running a 4" pulley. That's a pretty big pulley and he's still making 10 psi. In general a D1 will make 4 psi more than a P1 with the same pulley. Also in general for every 1/10" smaller pulley you will get 1 psi more. That is a general statement because the larger the pulley the less efficient the blower operates. I have a P1 with a 3.7" pulley making 9 psi. Add 4 subtract 3 and you get 10. Which is exactly what he said he was getting.As an FYI....my setup is on the stock Procharger Cold Air Intake...I'm thinking you do not have a D1 or something.
Again, an example of something you cannot compare without more information. It is highly unlikely that the motor made 518 on boost alone. 14 psi on a mostly stock 4.6 usually results in around 430-435 rwhp. So is 518 a corrected number? What was the correction factor? Did it have cams? Was it running E85 fuel? All of that makes a difference.Not sure the difference between blowers but I have a V3 Si trim - 14psi with blower cams did 518rwhp.
Some dyno charts have the information you need and some don't. Some will just say SAE corrected. Some will print out the correction factor and other data. Here is my last dyno chart. It is STD corrected. At the bottom it gives the data and says the correction factor was 1.02. That means actual horsepower for the day was 388 (396/1.02). Because I know that my other dynos were SAE I asked what the SAE number was. He told me it was 383 rwhp. The difference between STD and SAE averages around 4%. SAE always reads lower. On this day, the difference was only 3.3% lower.Anyone on here good reading the dyno chart and have instagram? Message me @mustang_Eddie
Very good points. I believe the 518hp was corrected so at worst probably makes around 500rwhp. This is a 4.6 / stock heads with blower cams and a blower @14psi peak on pump 93. 10:1 compressionAgain, an example of something you cannot compare without more information. It is highly unlikely that the motor made 518 on boost alone. 14 psi on a mostly stock 4.6 usually results in around 430-435 rwhp. So is 518 a corrected number? What was the correction factor? Did it have cams? Was it running E85 fuel? All of that makes a difference.[/url]
Interesting seems odd to be running out of fuel with your setup. Its hard to tell from the graph since its seems to stay under the 12.0 range throughout redline. Although if you look at the red line which indicates almost 10psi you are going a bit lean at 6100-6200 rpmHopefully this works. I do remember my tuner mention that i was running out of fuel. Can you tell from the graph?
