1 - 9 of 9 Posts
I'm wondering if anyone is running an Eddy with a stock type plenum. I only want to do an Edelbrock manifold due to some minor seepage at the crossover of my stock PI. Being the owner of two '01 GTs with the plastic coolant crossovers, I knew this day would come. I'm not buying a used PI intake, not paying $200 for a new one. I'll simply spend the $300 on the Edelbrock, pick up an adapter to run my stock plenum and TB. I consider the additional cost of fuel rails to be a worthwhile cosmetic upgrade, also.
It's a shame this didn't happen a year or so from now. I'd be a lot closer to dropping in a 4 valve. The irony of having a mint Mach 1 intake setup sitting in my house, and then dumping money into a new 2V intake.
Now, I'm wondering how insane the torque losses will be down low. This will be on my T56 car with 3.73s. My 1st gear runs out a good 5 MPH faster than a TR-3650/3.27 car, so it's never been crazy in 1st. Don't want to lose all that much torque down low with that in mind. Any numbers, preferably a dyno sheet, of a relatively stock 2V with an Eddy and a stock type plenum would be greatly appreciated. I'll be going through with this regardless, just want to see what I'm in for.
Also, another big question. What's everyone doing for a fuel rail pressure sensor? I see MMR sells a complete fuel rail setup with the rails, fittings, lines, and the adapters to connect to the factory lines and FRPS. Seems like the most well put together package, but it's pricey at $359. Manifold and rails would go on my other GT eventually, that'll be a 2V/turbo/automatic setup. So, the high initial investment over just replacing the PI intake doesn't bother me too much.
MMR makes an adaptor to run stock plenum with eddy intake
I know, man..
I'm interested in the results of this, though. I know that the low end torque losses are pretty considerable even with a 6061 or Edelbrock elbow that's designed for it, let alone a stock plenum ran via an adapter.
It was only like the 4th sentence in, so I guess you just read the thread title only. :lol
Found the results I was looking for. Edelbrock Vic Jr with an adapter plate and a BBK stock type plenum on a stock 2V. He went from 255/302 rwhp/rwtq, to 252/266, but the powerband was massively shifted.
Just to give you a ideal of what it will look like, hear is a picture of it on my supercharged setup.
https://lh3.googleusercontent.com/-7WP6XsRhefg/UwYLak2ZzmI/AAAAAAAAAEg/nhpK82JnOlY/w875-h495-no/d1sc+start+up+007.jpg
https://lh5.googleusercontent.com/-kezCLH511Jk/UwYJ_TxAMpI/AAAAAAAAADk/Yst0qQ5johE/w875-h495-no/intake+install+128.jpg
Discussion Starter #9
I ended up going with a new FRPP PI manifold. That made it a bit easier to afford a complete set of Mishimoto silicone hoses, new thermostat neck, new coolant temp sensor, the appropriate alternator bracket, fresh injector O-rings, EGR block off plate, etc.
Can't wait to clean the hell out of my throttle body, plenum, injectors, delete the EGR, delete the IAC silencer box, and clean the hell out of the entire engine while the intake and everything else is off. Was dead set on the looks of the Edelbrock, but the torque losses.. I think of the occasional times when I drive my BMW 325i, and realize how dreadful a lack of torque is.
1 - 9 of 9 Posts
