Will a TFS Stage 2 cam, duration @ 050" lift 224/232- lift w/1.6 rockers 542/563- lobe sep. 112 degrees work on a stock '93 5.0 (hypereutectic pistons) with Twisted Wedge heads? Does anyone run this combo because I called Trick Flow and they said I would have to check piston to valve clearance. Thats not a problem but if someone else had this set-up at least I'd know if its feasible or not before I waist my time claying-around.
