1 - 18 of 18 Posts
got a few dollars left, was wondering what i should spend it on, got about 2 options:
1. pistons, rods & kenne bell bap, for a 450 whp setup
2. svt cobra bumper, hood & some new shocks & struts
thanks guys
I say #1- but it looks more expensive than the bumper...
Beat the Cobra before you look like a Cobra...
Option 1. Better to keep your car running than to have a sharp looking paper weight
You're already supercharged, so unless the car is dog slow get some nice suspension upgrades! Shocks, Struts, rear suspensions stuff (panhard bar, sub-frames, lower control arms)
I say go for the internals first, they're more likely to fail before the suspension at your unknown power levels.
BYAHHHH!
what are your plans for the rods/pistons?
IMHO to make it worth going into the block to upgrade it your better off to put bearings, ARP hardware, oil pump, ect. Then you needs the gaskets and such.
Discussion Starter · #11 ·
i havn't started researching yet, wanted to get some low compression pistons & rods. actually going to call cushmanmotorsports and ask which would be best for my setup. when i go into the motor i'll be doing all the small necessary upgrades you mentioned scott and upping the boost to 12-14 psi
Discussion Starter · #14 ·
this is sort of what i was thinking :
Manley Forged P/R Kit - 11cc $1,469.00
Kit comes with Manley 14042-8 forged rods, FM 8-7250CH high performance rod bearings, Manley forged 11cc pistons and matching Manley ringset. Pistons available in bore sizes of STD, +.020, +.030., and the cms stage 2 blower cams, since the trickflow's didn't work
i would say option 1 but then again i'd blow the engine up before rebuilding it...unless your just gonna keep the rods/pistons in storage till it blows :D
1 - 18 of 18 Posts
