1 - 4 of 4 Posts
Baker Jr.
Wondering if i should use stock torque specs for these items or if you guys know them.
Im using ARP bolts. I need the flywheel to crank torque
Also the pressure plate to flywheel. Its a centerforce dfx clutch and a spec billet steel flywheel. Using ARP 12.8 strength bolts also
contact arp would be my advice
usually if its new the package will have a piece of paper with 3 or so torque specs depending on if you use engine oil, arp lube etc etc
Head Unicorn
I called ARP directly and they gave me their specs which work fine for n/a motors. On s/c or nitrous motors I follow their torque specs and a little more.
After final torque let the motor sit for 12 hours and then back the nuts off. Retorque to ARP specs but add one final torque step................ After ARP'S final spec torque to 110 lb/ft. The studs will hold, trust me and all the lightning guys.
1 - 4 of 4 Posts
