built auto is better for drag hands down
yes that is another thing thats on my list split port swap, was going to get some heads, upper an lower intakes, and cam from super six, just have to see how it pans out, trying to fix some problems with her right now, tapping noise. I just replaced the an exhaust manifold that was cracked, and all the rockers and pivots on both heads, still tapping when giving it gas. thinking its the lifter, just can wait to have the noise gone so i can start some modding. t-56 you should go for heard that trans can take a beating.Stage 3 heads, and a split port swap?
I'm going t5 or t56 soon, its just more fun.
who said that?thanks for the comments everyone, i know manual is more fun but i plan on putting alot of power through my 6 thinking auto is a better route for bigger hp numbers
I did the t5 swap, and I couldn't be any happier. Best mod I've done hands down. What kind of numbers are you looking for with your future setup? I'd suggest the 5spd, unless you plan on making some serious power.
i didn't mean that the t-56 could handle the hp cause i know it can just like you said, i ment it would be easier to use with hight out put of power, not having to shift, and missing gearswho said that?
they make t56s strong enough for 1000rwhp...yes 1,000rwhp+.
Auto is just the way to go if you actually do go through with it and decide to make power.
it takes all of 300whp to break a stock t5.....300rwhp isnt too serious at all..
my goal is 400+ hp, i want to build the motor as much as i can and get as much na hp as i can then put on a tc. i mean i will be bringing the car to the drag strip from time to time, but mostly daily driver. been trying to bring the car to the track to see what it puts down almost stock, but having trouble, with some ticking noises, can't seem to figure out the problem. Im just on the fence with the auto or 5 speed, becaue my current auto is not shifting that well anymore, so thinking it might be a good chance to drop in a 5 speed.I did the t5 swap, and I couldn't be any happier. Best mod I've done hands down. What kind of numbers are you looking for with your future setup? I'd suggest the 5spd, unless you plan on making some serious power.
Split port swap, I'm going t5 as soon as I get some free time.my goal is 400+ hp, i want to build the motor as much as i can and get as much na hp as i can then put on a tc. i mean i will be bringing the car to the drag strip from time to time, but mostly daily driver. been trying to bring the car to the track to see what it puts down almost stock, but having trouble, with some ticking noises, can't seem to figure out the problem. Im just on the fence with the auto or 5 speed, becaue my current auto is not shifting that well anymore, so thinking it might be a good chance to drop in a 5 speed.
awesome, let me know how the swap goesSplit port swap, I'm going t5 as soon as I get some free time.
well going the t/c'd route thanks, think i might drop in a 5 speed this summer since the auto is slowly going anywayif your goal is 400hp...assuming s/c'd...i'd go with a 5speed
