1 - 20 of 26 Posts
MM's resident Juice head
Okay i was talking to the crew chief of a friend of mine...He works on a 7 second S-10 with a 600 horse fogger! Anyway he has worked with nitrous for about 20 years. He is telling me that there isint much need for me to run HT0 plugs with only a 100 shot. This guy purges more nitrous than I burn so I would like to think he knows what he is talking about. Anyone here sprayin on factory plugs?
I already am...just wondering if it was a waste or not.
I run the ford racing plugs = HT0's
Don't think the stock plugs will last very long with the spray.
Hey Ken, whats your A/F under the spray?
is that with 4 degrees pulled?
thanks man...just trying to get some feedback from guys spraying their s-197's
Discussion Starter · #11 ·
no im snowed in up here...Just trying to get an appointment with the dyno.
Discussion Starter · #13 ·
are you automatic
yes, also that's not with all the mods in my sig.
since than I added torque converter,3:90's and O/R H-pipe
Discussion Starter · #15 ·
So I can expect a tad more RWH with my standard...Whats your fuel pressure running at?
Hey, I'm in the process f getting my ny-trex system installed and I was wondering if yall had to uprade fuel pumps, andif not what kinf of duty cycl are yours running on the spray. I'm wondering the same thing too Procharger about those plugs, cuz they damn sure werent cheap.
Discussion Starter · #19 ·
stocker pump is fine...fuel pressure runs between 35 and 62 resp.
Saaaweet, I was a little concerned. Are either of you running multiple stages or a window switch? I've got a trick performance dual stage window, I did it for a couple reasons, mainly for the safety it gives me, I'll likely be running a 125 shot. I cant wait, and from the soundof you guys the investment will be well worth it.
1 - 20 of 26 Posts
