1 - 18 of 18 Posts
i have a 95 cobra that im swapping an aod into. i know ill need a flex plate torque converter i need to know what else i might need, and the length of the shifter cable if anyone knows
thanks
(420 lbft of trq and wc t-5 equals BOOM)
is the wiring harness the same?
Resident Headbanger
If you're building your Cobra only for bracket racing, I suggest you go for a built AOD from Lentech. Yes, you'll need the flexplate and TC (get an upgraded higher stall version of that) and you'll also need the TV cable. To make the TV cable work properly you'll need to convert to a Fox throttle body/upper intake set-up.
if you are not driving it on the street much i would go with a built c4. will be equally as strong and is lighter and will take less power to turn it then an aod.
Priest of the Car Gods
2 of my friends have ran stock C4s with a good stall to low 7s in the eighth on 175 shot , Ive never seen a stock AOD do that
Is that because they blow up, or because they eat too much power?
My understanding is that the AOD is an FMX with OD, and that the FMX was the medium-duty transmission used in the 60s/70s between the light-duty C4 and heavy-duty C6. Based on that, I would think the AOD stronger. BUT, that's just theory and conjecture, not based on any actual experience with pushing either tranny to the limit.
Discussion Starter · #15 ·
and im 20 years old ive spent all my life savings and more this car to get the motor right so now im in the process of breaking and rebuilding my drivetrain... sorry cobra purist... but the ultimate plan for my car is a 400rwhp all motor 347 that revs to 8000 rpm with a irs out of an 03 04 cobra and a t56... track day car
8000 grand huh? and 400 on a stroker is ok but with the right combo you should make more and not have to go near 8000 rpms. What mods do you have now?
If that's your ultimate goal, why swap an auto in it now? And why would you want the IRS, when you could have a 3-link setup that's stronger, lighter, AND handles better?
1 - 18 of 18 Posts
