Automatic to manual computer
1873 Views 3 Replies 3 Participants Last post by  Melanie8992
I have a 1998 mustang with a 2000 v6 automatic engine, but transmission is a manual. Do I need to get a v6 manual computer for the year of the engine or the year of the car? I know that I can’t use an automatic computer on a manual transmission cause the computer will look for shift points when I will be the shift point.
1 - 4 of 4 Posts
You’ll have to use a 98 specific ecu. You can use the stock one and have the auto functions turned off if someone will do that. And if you have pats, you’ll either have to turn it off or have your key programmed to the new ecu.
Expertise – It is not impossible to convert your automatic transmission into a manual one, but it can be extremely complex. It requires experience with mechanics and you will need to have the right tools on hand that goes beyond the average tool box.
Manual cars also go faster than an automatic. This can be fun, sure, but can also lead to more tickets and accidents. Manual transmissions are also a lot less complicated than automatics and are therefore less expensive to repair.
krnt.run
myindigocard app
See less See more
My fiancé is a mechanic and works with other mechanics who have also owned mustangs. I’m just trying to figure out if I need a manual computer and BCM for the year of the car or the year of the engine
1 - 4 of 4 Posts
