1 - 20 of 58 Posts
MM Addict
alright so in the past i use to run with my buddie who had a 350 iroc using a stock intake manifold recentlty i just slapped a cobra intake manifold on and now my car wont hold its own against him why would this be? im still using same throttlebody and maf just a different intake
DEC '12 ROTM CO-Winner
That timing could have made quite a difference. Would have been better too if yours wasn't over heating and had that leak of course.
MM Addict
thermostat isent opening properly because the top radiator hose is getting alot of pressure and i can tell nothing is getting pushed through it
Did you remove the dizzy to put the intake on ? Did you put it back in right, did you pull the spout conector when you set the timing ?
^^^ Was going to say the same thing.. what do foxes run at? Mine just likes to sit at 195º
I have a 160 t-stat and an aluminium radiator/electric fan combo and mine sits around 150-160 causing. In traffic it'll go up to 180ish.
Sent from my galaxy s II
MM Addict
Discussion Starter · #13 ·
i think i accidnetly got sealer on the thermostat and thats what is causing it to overheat i think it got it stuck closed..
did u pull the dist. Check for vaccum leaks and that everythings set up right
it probably cuz you skip 3rd gear lmao
Still waiting...
Mine seems to run pretty cool, of course I'm going off of the stock gauge, so take it for what it's worth, but it hardly ever goes above the A in NORMAL.
1 - 20 of 58 Posts
