1 - 9 of 9 Posts
blah blah blah words
My reverse lights are not working. I have a manual, so I don't know when they are supposed to go on, (only driven auto's before, and the lights go on when you are in "R" and you hit the gas)
I have checked the fuse, it was okay. I noticed that it was a different color than the others, and in upside-down (in relation to the others, if I remember correctly they don't need to go in a certain way. this indicates that it was changed before?) Even swapped in a good fuse from another circuit, so it's not that. I find it difficult to believe that BOTH bulbs are burnt out so... help?
2000 v6 manual, (if that matters)
well pop out the bulbs and check if not the connection is on the side of the tranny it could have popped off I believe on the drivers side
Just Cheesin'
Drivers side dead in the center on the trans. It has a rubber boot over the connector. Pull it off and put a fused jper wire between the two terminals on the connector and see if the lights come on. If they do, replace the sensor. If not, it's a wire problem.
Check the bulbs first though.
Fuses can go either way.
MM's Official Lucifer
I just had to replace BOTH my bulbs, and they went out at the same time or within a day of each other. Money on bulbs.
And FYI they go on when you shift into reverse.
I guess i just found out why the left side plastic retainer is missing...
I am not sure what a dead bulb looks like, but it looked intact.
I guess someone else, (PO or dealer?) knew about the lights and checked the bulbs, because as stated above, the left side retainer screw is missing and there were only 3 nuts holding the assembly on. whoever tried to fix it must have tried the bulbs and the fuse, and then lost two parts :mad:
2013 5.0
Dead Bulbs sometimes have a burnt look to them...
Many times they look like ordinary bulbs. The best way to check a dead bulb would be to swap a working/new bulb in.
Just Cheesin'
Did you put liquid teflon or teflon tape on the treads? If not it will eventually leak past the threads.
1 - 9 of 9 Posts
