After much searching and reading as well as changing parts and trying different tunes i am at the end of my whit and really just need some help. I have a 2004 Mustang gt it has a few bolt on mods nothing extreme however about 2 years ago it developed a bad hanging idle. It has pretty much sat in a garage since i didn't have time to mess with it and was frustrated. When i start the car it runs fine and even drives fine until i get over 1/3 throttle. At which point when i come to a stop sign or red light the idle is about 2200 rpm and holds there for about 8-15 seconds until it suddenly drops and the car dies. The car pulls hard under WOT or in other words seems to act fine. I have have had no luck at solving this problem and am really hoping someone can offer some help. The car has just been rotting in a garage for years now and i would like to do something with it.
Parts i have changed and repairs i have made// changed IAC, changed TPS sensor twice, adjusted throttle set screw to fully closed, blocked off PCV valve in case it was leaking vacuum, cleaned MAF, Then replaced the MAF, I have also unplugged the IAC while vehicle was running and the car dies right away so i can rule out bad vacuum leaks, I have purchased two different types of tunners and even had a custom mail order tune done neither helped, only trouble code in the PCM is a EGR code and that is because i removed all EGR equipment, I even have attached a data log file to this post in hopes someone might be able to make heads or tails out of it, It was taken with a SCT x4,
I am open for suggestions as at this point i have no idea what this could be...
