1 - 8 of 8 Posts
this is what it is doing :(. i know you have to burp the radiator but this is rediculous. the water is like boiling out. the temp gauge is fine but i have to keep putting water in it.
Resident Know-it-all
PUt the radiator cap back on it. What's the issue that you are running your car warm with the radiator cap off?
Still slow.
The point of your rad cap is to pressurize the coolant which raises the boiling point higher. With it off the boiling point is to low and confusing the car. Definitely keep the cap on.
with the cap on the it steams out the over flow. all of it.
Rollin' 18/ pushin' 2
:dunnoDo you have the right water pump on it? Wrong rotation maybe?
i got it i since it had been setting out the whole time it was apart there was a giant clog in one of the tubes which was making air an air pocket that wasnt coming out therefor heating the water to boil it. i shoved the water hose in the tube and made it come out lots of mud and crud. had to take all the tubes off and clean it out put it all back together filled it up it burped a little now its all good going to get some antifreeze when i get paid. still not street legal still have to fix my tail light.
1 - 8 of 8 Posts
