1 - 6 of 6 Posts
I started getting a little vibration not to long after having my 4r built and changing gears from 4.10 to 3.73. I let It go for a while but it got worse and then back to very little vibration. So last night I put it on a lift and found my trans mount was completely gone and it actually caused my mid pipe to come loose from being pushed on by the trans. I replaced the mount and fixed the mid pipe, but now the vibration is worse, prolly cause the mount is fixed and I can feel whatever us wrong, loose, broke or whatever. I did check the u joints but they looked fine. Any ideas what going on that could be taking out my mount vibrating bad under acceleration and deceleration at all speeds.
Those are good, too. I actually originally thought that was the problem. Ordered some upr solid mounts and they just showed up an hour ago. I was going to start on it last night but seen they are good.
Could it be my driveshaft is wobbling or something like that. I'd hate to take it to a driveline shop
I was actually going to say that but i figured it would be hitting something. Id check the driveshaft just to be safe
I finally got some time to look at my car further. Driveshaft looks fine balancer still on it u-joints look good.
I am however getting a little play in my rear wheels when moving them around. I can push in and out on wheels until c-clip catches but passenger side will screech a little. Also wobbles, more on passenger side though.
Please help!!!!
Do I need to change bearings if so can anybody tell me how to get bearings out do I need a special tool?
1 - 6 of 6 Posts
