Im in the process of doing a battery relocation and wanted to make sure that the negative cable just has to go to any piece of metal to be a good ground. Is this correct?
I just relocated mine and I have a coupe. What I did was i ran my negative wire down to under the back seat. backed of of the seat belt bolts out and put the ground under there and tightened it back up. no problems so far.
mines bolted down right in the corner of the hatch...and theres a whole covered by a grommet thing that runs down under car..then just bolt in on a piece of solid metal...clean peice too...
how did you guys run the positive to the starter solenoid?
im planning on running mine under the car, maybe try to run it through the frame, is thats goin to be possible... Im just goin to connect the positive back to where its mounted now, which doesnt seem to be right to the solenoid, maybe theres another wire that goes there?
