1 - 5 of 5 Posts
im about to order some gears, but i didn't know if i needed to order the installation kit or the bearing kit... what are the bearings for and are they worth it?
unless you have alot of miles on ur car... 25k+ you wont need the bearing kit. New bearings are needed because the original bearings are damaged when taking out the old gears, but on a relatively low mileage rear, you wont need new bearings becuase, if the installer is good, they wont be damaged.
1 - 5 of 5 Posts
