1 - 7 of 7 Posts
what size bell housing bolts does the 2002 4.6 2v use? need to get the motor on an engine stand but dont have the bolts :mad:
If someone doesn't answer you shortly I will run down the street and measure the one I have laying on the shelf. Knew I should have bought a thread gage.
thanks for the help where should i go to get them homedepo or autozone ?
Got mine from Advance, but I am sure Autozone has them. Just go to the counter and give the guy the size you need. Don't know if that is the length you will need since its not going through the bell, so measure the thickness of the stand or get some washers to take up the space.
thanks for the help man
1 - 7 of 7 Posts
