1 - 20 of 54 Posts
So my dad is almost ready to pull the motor out of his stock 1994 GT for us to rebuild and he's throwing some crazy ideas out there. Like putting two 4 barrels on it and some AFR 220cc heads. Now I don't know too much about matching up the right sized heads for engine builds but I told him 220cc heads are a crazy size for a stock 302 and that he should at least stroke it to a 331 maybe even a 347. But he wants to leave it stock bore and stroke as long as the crankshaft isn't damaged. So what are the best/most aggressive heads and cam combo out there for a stock bottom end 302? Car will probably only see the strip with maybe weekend cruises once a month.
For a naturally aspirated combo I would get a nice set of AFR 185's and talk to a cam grinder to see what they can make you. Custom cams really are not that much more expensive and are worth it.
Is he looking at going carb? If so that will affect his other options, and would require a tune along with several other conversion items.
If he wants something crazy you should be looking into a 351w or BB swap.
Yes he's dead set on converting to a carb. Because he thinks fuel injection parts are too expensive and claims he'll get more power going carbed. I think he said he wanted either two 450s or a single 750. And I've tried convincing him to just buy a replacement 302 that was already running but he's just set on rebuilding this one. So I know he won't buy a 351 or a BB. I was thinking the 185cc heads as well but what do you mean going with a carb would require a tune?
I should have worded better. Not going carb will require a tune along with a lot of other supporting mods, lol. Carb will require a different distributor, ignition box, fuel system, intake and carb of course.
750 carb is going to be a bit big for a 302 but could be a fit for the 185cc heads and good cam. Whatever he does keep him away from the dual carbs.
Sounds like bar stool building. Nothing wrong with using carburetors but I think since it's EFI already you would be better off sticking with it. Unless he is good at making custom manifolds or has some cash to blow a dual carburetor setup is pretty unrealistic. The best and simplest way to do it without bastardizing the car is to keep it EFI.
I agree about keeping it EFI, but some guys want carb. There are a lot of off the shelf parts for carb, single and dual setups included. All in all it is significantly cheaper to run carb vs. efi. My first couple builds were on a carb 302 in a 79 notch, boy do I miss that car.
I've been trying my hardest to convince him to keep it EFI, but I just don't think he will. We've got to April before our local tracks open up, and it should be running by then with whatever he's wanting to do. So going the carb route, what would have to be changed regarding the fuel system?
Powered by LSx tears
It would be crazy to convert to a carb, but if he's going to, I'd put Trick Flow FAC190s on it, with a Victor Jr, and a Bullet cam, with the supporting valvetrain components.
yeah going to carb in these cars are dumb, unless your stroking the crap outta it and putting the big large port heads and blueprinting the engine. basicly saying. if your going to do all that "converting" go big for the track and do it right. if its just going to be something he'll take to the track just to have some fun and drive home id keep it EFI. the parts rarely go bad and arent that pricey these days and youd make more hp with efi vs carb, less adjustment and constant retuning and rebuilding the carb, changing jets, etc. some people say going carb is cheaper but id have to disagree. with all the time and the money, tools keeping a carbed car running you might as well kept it efi. besides that, a regular 302 cant handle huge carbs and i heard some ran faster with a two barrel. your dad sounds like my father in law. after working for ford for 30 years and his own cars. he swears by efi now. good luck. btw, you could go find a 460 in a junkyard and carb that, ooohhh, it would tote the wheels 2 feet lol !
maintnance man. fuel injection isnt that bad on maintnance. carbs always start leaking fuel, the trim screws back off from the vibration, its just a crude way to deliver fuel these days, unless its a track car that your contantly fiddling with anyway. dont misunderstand, im not ripping on carbs that much. im just stating if its going to be a dialey driver/ drive to the track and have a little fun and drive home car then i wouldnt go carb. but whatever. its his motor and car. if thats what hes set on then thats his business.
Discussion Starter #13
Haha well it's not going to be his daily driver. But he was complaining about how expensive bigger MAF meters and bigger fuel injectors are.
Well, for the cost of converting, it's a wash, and you'll gain nothing from the swap with the type of setup you're talking about running, and really the EFI is better for this setup.
With that said, the BS you hear about carbs is typically that.....BS. Carbs do not need constant maintnence, they do not constantly leak, or constantly need adjustments. I've owned lots of carbureted cars/trucks, and in fact, I think I've had at least one in my garage for the last 17 years. I can use the current one for example.
I built this engine 2 years ago, and took very little time to dial the carburetor in. I think I made one jet change, an idle bleed change, and set the idle, and I haven't touched in since. Oh and it's a street car AND a track car, and there's been no tinkering and/or fiddling. It's never leaked, the idle air screws haven't vibrated out, I've never retuned it, damn sure never rebuilt it. In fact, I don't recall ever rebuilding a carburetor on anything I've ever owned.
But, you guys should stick with EFI on a car like yours.
When you combine the fact that 24 lb injectors and a matching MAF really isn't that expensive and the fact that half of your electronics won't work anymore it's really a no brainer. What you're going to be left with after all is said and done is a hacked up wiring harness and non working gauges that you'll have to hack up some more to get working.
There is absolutely nothing wrong with carb'd cars as long as they either A: came that way from the factory or B: are purpose built race cars.
Also, the statement about carb'd parts being more available than small block EFI parts is complete BS! Perhaps when you're dealing with SBC's this might be the case but not Fords.
All in all, you will end up spending about equal amounts for which ever setup you go with. Also, you will lose low end torque going carb because you loose those long runners! That low end, long runner torque is what made the 5.0 Mustang famous!
I don't think anyone mentioned that carb parts are more available than efi parts. If your referring to my mention of there being plenty of options for carb then that has nothing to do with EFI and I was dispelling the previous post about needing custom manifolds.
Now if his father wants to run carb that is his choice and having built several carb'd and efi cars I will say that carb is significantly cheaper.
We are talking new parts for everything here so many of these items for the swap will be out already. He could most likely make money off of the stock parts he removes to help with the build.
Remember I am not saying that he should convert, but if he wants to why stop him from what he wants.
I misunderstood your post about "off the shelf parts". My bad.
btw trick flow ftw you can run any head smaller than 200cc
anything else bigger than 165cc you will need different pistons
Discussion Starter #19
Oh I didn't know that. Is that the same with AFR 185cc heads?
1 - 20 of 54 Posts
