yes you have to replace the valve train the stock one isn't strong enough or capable enough...iv never done anything like putting a camshaft in before, but i know its a pretty decent amount of work. would i have to get a new timing chain and watnot, or woudl the stock one work out fine? also, if im getting a new camshaft, should i go ahead and get new rocker arms, push rods, and spring while im at it? wat would be a decent cost for the parts to do this stuff right and do it once lol (if i was gonna tear the valve train apart id only wanna do it once.)
yes and no. you will want a good set of heads and ported intakes. however you my want to go with different / better valve train set up.so would my best bet if i wanted to put the money towards it would be the stage 2+ from ssms? http://www.supersixmotorsports.com/pdf/SSM2007catrev3PowerPaks.pdf
i offer the exact same heads with those valves, only the exhaust is bigger!so would my best bet if i wanted to put the money towards it would be the stage 2+ from ssms? http://www.supersixmotorsports.com/pdf/SSM2007catrev3PowerPaks.pdf
well as far as power its basically allowing more air to exit the combustion chambers which will result in more air leaving the exhaustlol i was gonna ask u chris wat ur prices were dont worry i wasnt gonna actually buy from ssms but i was just looking at them to kinda get an idea on prices
anyways, would the bigger exhaust be better for power? would it reduce torque at all or would it improve it? i honestly know very little about the valvetrain besides how it basically works wtih the camshaft and how it feeds the cylinders, but i dont know much abotu the sizing and watnot
There are a bunch of variables, of course, but probably ~240whp, give or take.just for kicks, if i have a stock motor, and did intakes cams exhaust (LTs with catted shorty midpipe) tune ported heads high flow air filter and maybe bigger throttle body wat kidna numbers would i be looking at?
