1 - 13 of 13 Posts
I somehow got white over-spray on my car. What is a good way to get the over-spray off of the black trim.
clay bar worked on the paint really well but it dont seem to came off the plastic stuff as well.
The first thing I'd try is a kitchen sponge (with the rough green back) and scrub with car soap and water.
Probably going to need to play around with chemicals. Just test the chemical on a small spot to make sure it doesn't fade or do something to the plastic.
thanks.. I'm headed outside to try.
might as well just polish it with the paint on there to remove it because you're gonna have to polish the hell out of it after that anyways.
try some kerosene or diesel, then rewax if the clay doesn't work.
clay bar and some elbow grease worked for me...had to do it twice
Got it off. Used a scrubber pad out of my kitchen and then the back to black, looks good as new.
Thanks for the help
Best way to get overspray off of glass is steel wool (0000 steel wool). Best way to get overspray off paint is a little paint thinner on a rag and wipe it on the car. Best way to get it off of plastic would be try using detail spray and a rage and just rub real hard. Dont use an abrasives though.
Even 0000 steel wool can scratch a window. Clay bar works fine for windows. If not, I'd use a brand new razor blade with a LOT of QD to lubricate the window. Why wouldn't you just use a clay bar, again, to get overspray off paint?
1 - 13 of 13 Posts
