Anyone have any idea on how to get it out? I washed off all the sh!t but there is still a stain and it like bubbled up a little. Are there any chemicals out there that will take that out?
lol nice! I guess I should start doing that tooMy car is black too. A couple of times I've had a bird **** on my car either while driving or when I really can't clean it off. I've pulled over and used spit and a good micro fiber rag to get the **** off quick.
If the car has an aftermarket paint job, then YES by all means do this, but with the stock paint job you will sand through the clear coat and cause paint failure. Shops won't touch your car with a wetsand unless you have a few extra coats of clear to spare. Ford, as well as just about 90% of other car manufacturers, do not put enough coats of clear on your car to do this efficiently.That's right. The only thing you can do now is try to make the damage less noticeable by lightly wet sanding the area with 2500-3000 grit then buff it. That will help, but no full fix.
