well I decided to buy Hitech Stage 2 cams. For 400 brand new! I know I wanted suspension but these were to good to pass!
Really??? Even though hitech says you dont need to degree them or use aftermarket springs?make shure to degree them (we've had three set's come thru with the cams having diffrent LSA's from one another & had PTV problem's) & use new spring's.
:lmao:lmao..................you'll never see another set in any of our car's. biggest gain I've seen out of them is 2 tenth's, IMO go another direction.Really??? Even though hitech says you dont need to degree them or use aftermarket springs?![]()
Sounds good, each to their own we all like different things. Butttt from what I used to read based off your post you want to build a FI monster in the future. How good are these cams going to do you in that sort of situation? Not very good...theyre not designed for such applications...If your sticking to factory shortblock, heads, etc with some simple bolt ons sure theyre good, but once you get into major things they hurt more than help. One way or the other though I think these things are way over rated reputation wise, and as you can see they dont give you a whole lot on the track; and id believe casper about track info over anyone on this forum any day.i put down 231 when the convertor locked up and 236 when it took a little longer. I hope with these cams I could get a pretty decent gain.
well being a college student and working part time I wont be doing the FI build till a full time job and school.
So I would get **** from these cams? .2 tenth sucks for that money
x2, comp 270 and degree emSave up and get some Comp Cams
