I have a set of speed bleeders and the Valvoline synthetic Dot3/4 fluid. The speed bleeders were bought from Advance Auto parts today. They brought up my car and it listed this part. Then we got it off the shelf.
Where exactly is the bleed valve located? I see a brake line going into a fitting on the axle side of the drum. These threads look to be the same size as the speed bleeder. If I remove this, won't air get into the line and nothing will get bled in the actual drum brake?!
Also see something that looks like a grease fitting. This is right next to the fitting with the brake line going to it and on the axle side of the drum. Is the "grease fitting" looking thing the bleeder valve? I have a Haynes repair manual, but it just says to loosen and bleed, but doesn't show which screw. I don't want to take off the wrong thing and put air in the line. Thanks!!
