1 - 20 of 32 Posts
hi guys i was wondering what are some good blower cams for my pretty much stock 02 gt im lookin for a choppy idle and im eventually gonna get a vortech so im tryin to get the most out of my car im also getting 410s, also what would be some good supporting mods to go with those cams? thanks.
Blower cams dont lope as much. I think the Comp 270 cams work pretty good for boost setup, and have a nice lopey idle.
I would look into some CMS 2.5 cams. Or Crower blower cams. Those actually lope pretty good. And great improvment, power wise.
springs/retainers are always good while your in there. Longtubes with cams will free up a lot.
Id go with a stall before cams if I was an auto...thats just me though.
Nothing is necessary, just opinion. If it were me, if I had an auto, first mods would be 4.10's, stall, shiftkit. That a lone will make the car feel ALOT faster without making any more power. If anything itll lose alittle power. But feel so much faster.
Discussion Starter #11
yea im lookin into 410s and cams if i can im gonna try to fit in a stall then eventually save the big bucks for blower, n what u mean lose a lil power?
Screw the cams, get the blower first. Use that $600 or more (springs/retainers) to put towards a blower setup.
4.10's take away from alittle power uptop. But its not anything noticable. Like 1-2hp.
I just say run a blower with an air to air intercooler at 9-10psi, see if you like the power, if you want more do cams. Blower cams with a blower setup usually pick up at least 50rwhp from what Ive seen. Thats going from AFM cams, to houston performance, to crower, to CMS etc.... I think Bandity picked up like 80rwhp with his houston performance S292 cams.
Discussion Starter #16 (Edited)
ya this is the second time of heard about andersons im gonna take a look at them, yea im just tryin to get some stuff done this season i would love to have a blower this season but the way the economy is idk bout this season so im just tryin to make it affordable right now. thats kind of a lot to pick up from blower cams i thought they usually range from 25-35?
OP, I would say forget the cams if you are going to add a blower later on down the road, unless you are planning on building a forged motor when you add the blower. With the cams and a blower, you will be on borrowed time with the stock short block.
If you want to stay N/A, then you can go nuts with cams and heads and your stock shortblock should stand up.
Discussion Starter #18
yea when the car eventually gets up there in hp im definately gonna get a new stronger short block. i dont think im gonna go n/a tho.
1 - 20 of 32 Posts
