1 - 7 of 7 Posts
hey guys, I was wondering who knows the best way to route the boost line from the motor to the cabin:confused:.
i just used a wire grommet
MM's resident Juice head
Brian,
Under the drivers foot pedal area there is a large rubber gromet where the wires come through the cabin
Jack up the front of the car, remove the drivers sidr tire, then remove the plastic inner fender...its held in with 4 push pin connectors...you will need needle nose pliers or a flat screwdriver. once the plastic fender is removed you will have access to the other side of the rubber gromet. cut a hole and pull it through....super easy to do.
1 - 7 of 7 Posts
