1 - 6 of 6 Posts
i have a 07 gt with a saleen supercharger and im about to get a computer program to bump up the boost. Whats a good website to get some info on what i can do safely? Right now im only pushing 8 psi but i want to go to about 12 psi but not hurt the motor. . .
you can also try.....Custom Tuning. He's a member on this site. check out the vendors spot
By your first post I can tell your knowledge of mustangs is lacking.
You can't bump up the boost with a tuner, you also need a smaller pullie as well.
You will not be running 12psi on your car either, it will last about a month before kaboom! The most psi you should run is 9-10 psi at the most!
The amount of boost means nothing. It depends on the amout of HP you are laying down, but generally 10psi ranges between 440-470rwhp depending of other mods and the tune.
1 - 6 of 6 Posts
