1 - 9 of 9 Posts
· Registered
well, I sold new old 2V and stepped up to an 05' 3V. Awesome car but i just noticed that im hearing some valvetrain noise coming from the passenger side head??? anyone know if this is common on the 4.6 3V? I have an extended warranty thru Ford and if something is f'd up I will want them to address it but I know how they get on warranty issues. The car only has 51,000 miles and was taken care of. Only mods are CIA, magnaflow catback, and a superchips can tune. My stang runs great and I have no drivability issues and anything but i get this damn anoying ticking, clicking, whatever from the passenger head? You can only hear it at an idle? Any suggestions??? thanks
· Registered
I've only read about one person having valve train issues that hasn't gone past the standard CAI mods. The guy ended up having a bent valve. IMO take that sucker back to ford and take the CAI off and return it back to stock.
· Registered
may be the cam phasers is what you are hearing..is so its normal....ticking noise?
· Registered
When I first bought mine the injector/cam phaser noise did scare me a little. Once I heard some other 3vs in person with the same noise it put me at ease. If you really are bothered by it take it in. IMO
· Registered
Agree, if it's like a "sewing machine ticking noise" it's pretty much normal. I think the cam phaser noise is slightly deeper,almost a mild knock but doesn't stay constant which is normal also..
Good luck
· Registered
I wouldn't jump right in here and say it's normal without hearing it. You say it's on the passenger's side. If that's the case then maybe you do have a real problem. It's not uncommon for a hydraulic lash adjuster to fail causing it not pump up which results in a sloppy, loose cam follower (rocker arm).
1 - 9 of 9 Posts
