1 - 12 of 12 Posts
ok so after i did a...medium sized burnout to get rid of my old tires the other day....when i go wot or right when i get out of the gas without pushing the clutch in. the brake light comes on...wtf? it only does it on the highway and it isnt flashing like it does when you pull the hand brake handle up a little while your moving. could it be the sensor for the handle? need help guys thanks!
US Air Force (retired)
Probably the brake warning light. Is your fluid level OK?
dunno what the computer tracks, but if it's none of that, it's probably just a loose sensor.
i will check the fluid level and is the sensor out actually on the brakes or by the ebrake handle?
1st check fluid level, if not that then its probably a sensor
My brake light comes on sometimes, everytime I drive it goes on for a few secs, then off and later it comes back on.... I think its the fluid level cuz I'm right by the minimum level line...
yeah i checked mine and i think thats what it is...i will top it off tomorrow...drove the car tonight and found out i need new brakes as well...right now i have like 500 bucks worth of maintenance bs to take care of
mine also does the same thing, when i get into hard and then just let off, the light comes on. checked the level and everything seemed to be fine
mine comes on when i start coming to a stop and press the brakes, the fluid level is ok, any suggestions?
If the fluid level is OK then I would bleed the brakes and the master cylinder just in case they picked up some air when the fluid level was low. That's cheaper than buying parts.
Happens in my V6, from what i've read/experimented with, its a loose sensor.
Discussion Starter · #12 ·
Problem Solved!!!
ok for all of you that have this issue, at least for me, it was worn brake pads causing a low fluid level. thus when you accelerate hard or brake it causes the fluid in the resevoir to move out of range for the sensor. since our cars have 2 piston calipers, ther is alot of space for fluid to fill when the pads are worn. i replaced the pads, and bled the master cylinder, both places, then the front right tire and the front left tire with all new synthetic dot 4+ brake fluid.
1 - 12 of 12 Posts
