1 - 10 of 10 Posts
a few weeks ago i was backing the car out of the garage when my gf told me my brake lights were out. when i checked them out all 3 brake lights were out, and the drivers side reverse light. i checked the fuses and didnt find any blown fuses. i checked the wiring and so far havent found any loose, frayed, or crimped wires. I would assume that maybe its the brake pedal switch but that wouldnt explain why 1 reverse light is out. does anyone have any input on the situation? Also, the turn signals and lights work.
I don't think you are getting power to the lights. Do your tail lights work? If not its definitely not getting power.
yea they work, its just the brake lights and drivers side reverse light that doesnt work
i think its a wire somewhere in the trunk. it happened when were were leaving to move out of state and i had the trunk full of stuff.
When I get off work I'll take a picture of what I need to unplug and re plug to get the brake lights to work. I had the same thing happen a few months ago.
did you ever get around to taking that picture?
Hardcore Devotee
Silly, but check the bulbs to see if at least one of them is coincidence. I thought the third brake light had seperate wiring but maybe I'm wrong. That's alot of lights to be out at once....
I am so sorry. I comptely forgot about this. I have a picture now. did you ever get it fixed? Its on the drivers side trunk by the tail light housing, behind the carpet. Just unplug and replug it :rockon
well, i did the plug thing and still nothing. i guess ill try the brake switch under the pedal. just doesnt really explain why the reverse light went out at the same time. when i get around to it ill try replacing the switch. in the mean time ive been driving my beater anyways.
  • Like
Reactions: FORDY9ER
1 - 10 of 10 Posts
