Ok so my tall lights work but when i push the brake they don't blink i use the turn signal it works my reverse would not work but now they do..... First i did do the brake pedal thing it was broken i fixed the little connector but it broke again so i bought some female connectors hooked them up and it worked so i don't think it's this i checked and there connected and not loose... One thing though is i added a third brake light led was not working so i unhooked it and saw the connectors were not making contact so i fixed it at first the driver side worked then it all turned off now when i depress the brake no lights turn on my taillights are tinted and no lights when i step on the brake dangerous not to mention my 30min commute is highway with cops all to eager to pull people over please if anybody has any tips/info thank you
