1 - 4 of 4 Posts
Hi guys,
I'm in the process of hooking up a line lock in my 92 GT. I need to get a few plugs,some lines, and a t fitting. Does anybody know what the port size is on the master cylinder? I have to plug one of the front brake ports. The port on the line lock is 1/8 inch. Also does anybody know what size the port is on the switch block? I have to run a line from the block to the line lock. What size t should I need to tie in the stock front brake lines? Thanks for your help
Resident Know-it-all
I use the factory line out of the master cylinder, then inverted flair the cut line. I use a 3/16" inverted flare T. I use a couple pieces of new 3/16" line in there too.
1 - 4 of 4 Posts
