1 - 6 of 6 Posts
Wiser by the Minute
Fellow Stangers! Hope all has been well. I have been gone for a few months but I am back. Almost sold the stang.
Got a brake issue. Front right caliper locked up. Replaced that. rear left caliper locked up. replaced that.
Power flushed the system.
Rear breaks are really weak. almost wont stop the wheels. If it dose i can still turn them by hand while the pedal is held.
Is this my Master CY? or is it the Proportioning valve?
What do you all think? Thanks!!! :mad:
Wiser by the Minute
Discussion Starter · #2 ·
Anyone? I am trying to get this squared away by 430 so I can get my part. :)~
Wiser by the Minute
no one knows huh? Any ideas?
Wiser by the Minute
Well I'll let yall know I guess -- I am going to try and just chage the Prop valve / proportioning valve and see.
When changing that do you need to bleed the brakes ? I am sure I do but just curious.
King Trashmouth
My guess would be proportioning valve.
Bad MC would cause them all to be weak, or fail, not selectively.
And whenever you open brake fluid to the environment, I would suggest bleeding the brakes. I also highly reccommend a speedbleeder, or vacuum bleeder. I did it the hard way last time, and it is just too much of a hassle.
1 - 6 of 6 Posts
