1 - 1 of 1 Posts
have both valve covers currently routed to a baffled Oil separator with a breather filter on top. I get minor smoke coming out of the filter, looks like less smoke then a cigarette. Also moves as slow as a cigarette smoke even if I push on the gas. Before people start going haywire that I have a problem with the motor, compression test and leak down test were both good. The smoke becomes annoying sitting at a light creeping up out of Cobra hood vents.
My Brether can
https://www.amazon.com/Vincos-Univer.../dp/B076BKV7JF
Option #1 I was thinking of removing the filter and routing those fumes back into the intake. Should I do it before or after the MAF sensor.
Option #2 remove the filter and route it into my exhaust pipe after wideband O2 sensor with one of those Vibrant Venturi part #1 1189 scavenger fittings.
https://www.summitracing.com/parts/vpe-11189/overview/
1999 Mustang GT Convertible
4.75 MMR 750se 10.5:1 CR Notched Pistons
Ported PI Heads CMS Turbo Stage 2 Cams Eddy Intake 75mm 60lb inj Twin 340lph Pumps Modified FPDM
___
1 - 1 of 1 Posts
