1 - 20 of 38 Posts
My 94 Cobra has sitting in my barn for the last 6 years with a shattered tranny while I was in the Navy. Now that I'm back home I've started working to bring her back to life.
While driving down the highway back in the summer of 06 something happened and the shifter blew out of the tranny, bell housing had a few pieces break off, the tail housing craked all the way around, and a few other big cracks in the housing. Dropped the ds down onto the exhaust.
Finially located a good used t5 with bell housing off a 94 GT to do the swap. Picking it up tomorrow and installing it. Going to change out all the fluids, new battery, and see what happens. Still need to do some work with the brakes and other things before I get it on the road. Just want to hear it start up tomorrow.
aloha ke akua
Sounds awesome, man! Good luck. Post pics after you wash her up.
Id like to see it as well
good luck getting her going again :)
Good luck.
Just got back home with the trans. Have to drop the old one out yet, just have one bolt on the crossbrace to remove and it will be out.
Good luck! I was in your position a year and half ago. Feels good to take it on that first drive.
Well got the trans and bell housing off. Noticed a couple broken studs and a hole in my driver side header. So I'm going to order some new ones and install while everything is taken off. So probably a week delay. Need a new mid pipe anyways since the ds dented the crap out of it when it fell on it.
I'm about to order BBK LT's with O/R X. Have BBK shorties on there now, figure I'd go with something to change it up a bit.
Discussion Starter · #12 ·
Well I went ahead and installed the bell housing and trans today. Here is a pic of the old one:
Ouch, that trans met with a horrible death for sure! Nice to hear it started right up, keep us updated! Pics and vids are a must!!!
Discussion Starter · #15 ·
Well I just finished replacing the U Joints and installed the driveshaft. Also hooked up the new speedo sensor. Would have went for a drive but we have a few inches of snow and the roads are all salty.
I only have the headers on, the studs that connect with the mid pipe are snapped and I get them out... Not sure what my next step will be on that. Also have new rotors and pads waiting to be installed. I'll probably wait until I know I'll have some time to drive before I'll throw those on. Other than that she is ready for the road!!
Post pics of the car, interior..... every thing
Better than Drugs!
b/c we were 15 minutes away from each other...thanks for the invite derek! haha. jk
I have mine pulled out right now and no joke, mine is the same way but on the back on the shift pedestal. Cracked all the way down.
You know you are going to bunker or muncie in the spring with all of us. Dont let me down!
Better than Drugs!
BTW-- did the studs snap off in the headers? Mine did the same on the one i have now.
I took a long screw driver and "punched them out" from the top.
Also, you can take a grinder, dremel, whatever, get a bolt that is too big, then cut of the head, grind down the sides square and manuever your arm/hand from underneathe and tap in the new bolts. by tappping i mean pound them in but dont f-- the threads up, ya know what i am saying?>
the same fun stuff happened when i put on the new x pipe. anchors away senor
Discussion Starter · #19 ·
Yeah they broke off in the headers. I'm going to grind off what sticking out then try to drill them out. I dont want to have to pull the headers so I'm going to try everything possible before I give up.
Discussion Starter · #20 ·
Haha you always seem busy. Plus no one wants to help me in my freezing ass cold garage haha. I'll def. be hitting the strip in the spring. Just need to find another tranny because I know this one probably wont last many hard launches if any.
1 - 20 of 38 Posts
