1 - 10 of 10 Posts
Faster than my X
In of couple of weeks my 4.75 900se shortblock should be coming in.
I want this motor to take 600rwhp easily here is the list I have :
Arp main studs
Oem head bolts
Mmr side bolts
Stock 03 cobra heads
Felpro headgaskets #1141 L & #1141 R
Oem timing chain set
Ford racing high volume with oil pick up tube
Oem 3v windage tray
Stock oil pan
Advice will be greatly appreciated and opinions are welcome
What recommendations are you looking to get? What heads, Bs or Cs? n/a or FI? What compression?
The 4.75s are only about 8ci larger than stock so don't expect any increase in power unless the compression ratio is higher (than stock).
Faster than my X
My plan is to go thru with this 4v swap and then in the future put on a turbo.
I already have the shortblock on order.the other stuff like heads and etc i have .
Faster than my X
Heads I have now are the earliest c heads from an 03 cobra.im going with stock compression.hopefully these heads don't have the tick.
BYAHHHH!
600rwhp with a turbo wont be a challenge at all...
Faster than my X
I'm going with stock compression which is 9:5:1 .what size dish piston will I need?10cc
Faster than my X
I thought 03/04 cobras had 8:5 compression .im going force induction and plan on going with dish piston.im looking for some pistons to net me a 9:3-9:5 compression.
You said you were going with stock compression ratio of 9.5:1 and never said anything about 03/04 cobra engines.
All 93-04 naturally aspirated engines had 9.85-10 to 1 compression while the 03/04 Cobras had 8.5:1.
If you buying an engine from MMR jsut tell them the compression ratio you want.
1 - 10 of 10 Posts
