Alright, my dad and I are finally getting around to ordering parts for our build. Our goal is 500ish at the crank with 400+ at the wheels with a engine built and a supercharger capable of pushing more with a simple pulley swap. Basically we may realize we want more horsepower later and do not want to be limited. We would not need anything stronger then something capable of 650-700 hp at the crank. Our one thing is to build up a brand new engine only keeping the bullitt manifold.Anyways here's my questions?
The research I have done has said the bare bones block is capable of 700 hp as long as everything, literally everything is replaced including rotating assembly. We want to buy the engine of of LMR code names Romeo from ford racing. It retails around $800. Is this information on its capabilities correct?
Can you guys give me an idea of which centri to get that can easily reach the hp goals and is able to improve with a pulley swap?
Which cam should I go with?
Which heads?
Pistons?
Rods?
Cams?
Basically if someone could give me a general idea of a engine part list that I should order and which stuff I should swap over?
It's a project with my dad and I so it's technically his car and he will be funding the project so money is not an objection and we would prefer the best parts available for the build so we do not want to cheap out.
I've done research, but I just want to know what you guys suggest and have experienced.
Which heads?
Pistons?
Rods?
Cams?
