1 - 7 of 7 Posts
Super Moderator
So the high speed fan is always running? Why did you wire it that way? The terminator has the same fan the gt has and has no issues even modified. I’m a proponent of not messing with the stock fan. Is the plastic air dam on the bottom of the core support still there?
The dam is still there yes but I just have a jumper wire going to the fan cause it doesn't kick on as early as it should. Do you think putting bigger filters on the turbos would help or...?
Super Moderator
What do you mean by it won’t kick on as early as it should? It’s computer controlled and if the tune was done correctly it should be coming on at the right time. Remove that jumper and put it back to factory. Verify that it’s actually coming on when you switch the ac on. It should always be running then. And no bigger filters would have no effect on whether it runs hot or not.
1 - 7 of 7 Posts
