1 - 20 of 22 Posts
So awhile back I was looking at CAI's on ebay, and I found a bunch that were only 20 or 30 bucks on there. Now when I look for a 2000 V6 CAI off ebay, they're anywhere from 70 and upwards? What happened to all the cheap ones? >.<
I've noticed that too, all the good ebay deals are gone.
I just went with one from americanmuscle.com $75 shipped minus whatever the discount is we get
I got mine awhile ago but i think i paid $50 for mine, n some **** was missin, pisses me off!! So i wanna get another one.
what u mean some **** was missing... it should have came with a couple bolts, 2 pieces of pipe, a plate that goes on b4 the filter, and a filter (if you got a fenderwell cai). then just put ur MAF on it and connect it.
wat r u missing
2 bolts n one of the things u use to connect it to the bottom of the fender. It rattles cause u can't tighten it down rite.
dont u have a local hardware store around your area? bolts are bolts......there isnt a special CAI bolt that you can only get with CAI.
Yea i know that, but i need the piece that goes in the rubber ring n that u put the bolt into, that connects it to the fender. Here is pics of the bolts i am missin.
no its like a metal or platic piece that goes into the rubber foot n the bolt screws into it.
MM's Resident Ricer
that metal thing is pointless I didnt have it on mine, just take that bolt and use it where the other one is missing, that one is kinda important to seal the gasket
also that gasket isnt right I had the same problem with mine throw away that gasket and seal it with silicone glue 10 bucks says you have a nasty vacuum leak right there.
1 - 20 of 22 Posts
