1 - 6 of 6 Posts
Take a listen to the link below. Guy I bought it from says it has an E303 in it... What do you guys think?
Powered by LSx tears
It was a response that matched the intelligence of the question. If anybody tells you they can tell anything about a cam, solely by the sound, they are full of ****. It's either not stock, or you have a vacuum leak. That's about it.
If you want to know, pull the timing chain cover off, and look at the number stamped on the end of the cam, or get a dial indicator, and a degree wheel, and check it.
Sorry man, I wasn't trying to be rude or otherwise... I plan to pull the front off, just thought someone could give me some insight.
:D
You have to bring your fire suit when you come in here. It defiantly has an aftermarket cam, but there's no way of telling anything about it by the sound. A lot of things affect the idle in a cam profile. There should be a number stamped on the front of the cam. You'll have to pull the timing cover, and the cam gear to see it. If you know how to use a degree wheel, and a dial indicator, you can figure out the actual specs.
1 - 6 of 6 Posts
