1 - 3 of 3 Posts
hey guys i want to install cams on my car but i have a question about the tuning. I know you need a tune with cams but what im wondering is that would a sct sf3/x3 power flash tuner be sufficient enough with the cams ( will it idle right with this tuner and what not). i know it wont tune in the cams. is it worth it to buy the tuner?
It should start and idle even without a tune but will be running lean. The best thing to do is get it to a dyno asap after the cam swap. The preloaded tunes on any hand held tuner will not be good enough to run with cams. What size cams are you going with? Are you doing the swap yourself?
duration 270/274
[email protected] 234/238
vavle lift .55
lobe lift .3
im doing the swap with my sister's bf (very good with cars, mustangs in-particular)
and a rough estimate on how much the dyno is please if you know?
thank you for responding
1 - 3 of 3 Posts
